Question
Yes/no toggle in custom intake forms?
  • Dec 5, 2024 4:40 AM UTC
  • 1 reply
  • 67 views
Hi all,  I’m new to SB and working to set up some customized intake forms.  In the pre-loaded questions, for yes/no questions, there is a little toggle button at the bottom that lets someone choose yes or no.  But, I’m not finding that toggle switch in any questions which I create myself.  I seem to be able to only use the “choice” button and then create yes and no options.  Am I missing it somewhere?
1 reply
Sara Sultan
Smokeball Team
Forum|alt.badge.img+1
  • Smokeball Team
  • Dec 5, 2024 12:49 PM UTC
Hello Holli,
You will only find the Yes/No toggle on older Smokeball pre-made forms.  We have since changed the form builder and that is no longer avaiable.  You can use the Choice Component and put in Yes/No or True/False as your options.
