Solved
Word document - cross-reference fields not updating
  • Sep 12, 2023 2:51 PM UTC
  • 2 replies
  • 225 views
I use a lot of cross-references in my Word documents (pursuant to para. 6.3; subject to section 8; etc.) But now in Smokeball if I insert a new numbered paragraph or section, the cross-references do not automatically update, and I have to select a specific cross-reference and update it individually. Does anyone know how to get all of the cross-references to update at once in Smokeball?
Best answer by JKibler
“Press Ctrl-A to select all paragraphs. Press F9 to update all cross-references.(This will also update other fields in your document, such as the table of contents.)” Source
I believe this is a common problem and not specific to Smokeball.
View original
Forum|alt.badge.img+1
  • Smokeball Genius
  • Answer
  • Sep 13, 2023 2:29 AM UTC
  • Author
  • Contributor
  • Sep 14, 2023 4:07 PM UTC
Thank you. That was very helpful.
