Solved
UI design causing frustration with less tech savvy employees.
  • Jan 20, 2023 5:32 PM UTC
  • 4 replies
  • 203 views
Jake Pazner
I hope this reaches the UI/UX team eventually. The way the matter windows are set up is causing unnecessary frustration. Unless you are using a vertical monitor, the current layout makes no sense.
The files tab floats over the matter details and can only be moved vertically. This makes it so you can’t really look at both the matter details and the files at the same time. You have to drag the files tab all the way to the bottom get a good look at the matter details or drag the files tab all the way up to get a good look at all the files.
With the files tab dragged to the middle of the screen you can see only a few matter detail lines and files with out scrolling. Some of our older employees zoom in on their screens which makes this even worse as they can only see a few lines and files with out having to scroll. Not being able to simultaneously view the matter details and list of files is causing unnecessary frustration. .
Simply having the matter details and files arranged side by side with the option to move them horizontally would fix this. Additionally having the option to hide the widgets and timeline tab would also be appreciated as it would leave more room on the screen to view the matter details and files. Attached below is an illustration of a more preferable layout.
Best answer by Sara Sultan
Hello Jake,
Thank you for your feedback.  I did pass this on to our Product team.  They wanted me to let you know that we have expanded our UX/UI team and have some exciting projects in the works!  I am not sure what is up next, but keep a look out for new changes to Smokeball.
View original
Sara Sultan
Smokeball Team
Forum|alt.badge.img+1
  • Smokeball Team
  • Answer
  • Jan 20, 2023 6:31 PM UTC
Hello Jake,
Ben
  • Frequent Scribe
  • Jan 22, 2023 10:40 PM UTC
@Jake Pazner, this is absolutely fantastic feedback. Thank you again for sharing it with us!
Would you be interested in jumping on a call at some stage to explore this or other UI/UX issues that pop up for you?
Jake Pazner
  • Author
  • Contributor
  • Jan 23, 2023 2:48 PM UTC
@Ben yes, of course. The sooner the better.
  • Contributor
  • Jan 14, 2026 1:33 AM UTC
I submitted this exact same proposal a few months ago and we still have no update - Fabulous idea and would love to see implemented. What a waste of nearly ¼ of the screen size with the current layout. And further functionality of setting specific layouts for specific things (e.g. tasks, memos, email, more comprehensive billing, expand contact information) based on the user’s preferences. For example, admin/paralegals will generally be more involved with tasks and matter details, lawyers more concerned with documents and emails. Imagine being able to set a default layout on a user-by-user basis depending of their specific needs. Would love to see where this is currently at, as the current layout is not friendly.
