Solved
Recording Due Dates Related to Inheritance Tax (Pennsylvania)
  • Sep 28, 2023 1:32 PM UTC
  • 7 replies
  • 111 views
How/where are firms recording the ITAX Prepay, Fiduciary Returns and Status Report due dates in the matter details?
Best answer by Sara Sultan
Hello @MFD
What matter type are you using?  In our Decedent’s Estate matter type on the Case Details layout, there is a spot to track the Inheritance Tax Due Date.  We may be able to add the other due dates as well if they are standard in Pennsylvania matters.  You can then use workflows to send you task reminders of the deadlines.
View original
Sara Sultan
Smokeball Team
Forum|alt.badge.img+1
  • Smokeball Team
  • Answer
  • Oct 4, 2023 2:40 PM UTC
Hello @MFD
  • Author
  • Regular
  • Oct 9, 2023 4:17 PM UTC
Thank you for the reply, Sara! There is an ITAX Prepay due date that is separate from the ITAX due date. It would be beneficial to have fields for each. ITAX Prepay, Fiduciary Returns and Status Report due dates are standard in Pennsylvania matters.
Sara Sultan
Smokeball Team
  • Smokeball Team
  • Oct 10, 2023 3:15 PM UTC
Thank you, Mary!
I have turned your post into a ticket so that I can connect you with our Legal Product team.
  • Author
  • Regular
  • Nov 1, 2024 5:00 PM UTC
@Sara Sultan can you offer any insight on when the above mentioned fields might be made available?
Sara Sultan
Smokeball Team
  • Smokeball Team
  • Nov 1, 2024 5:35 PM UTC
Hi Mary,
The Legal Product person that is working on this is out today.  I will update you when I am able to get a response.
Sara Sultan
Smokeball Team
  • Smokeball Team
  • Nov 8, 2024 4:20 PM UTC
Hello Mary,
This will acutally require a lot of changes and will not be available in the next 4 months.  That is all the update I have so far.  I am unable to say when it might be available, just that we are planning on updating it.
  • Author
  • Regular
  • Nov 8, 2024 5:01 PM UTC
This is disappointing news considering it has been more than a year since the initial request and these are standard dates for Pennsylvania matters, but I do sincerely appreciate the update @Sara Sultan. Thank you.
