Solved
outlook issue
  • Jun 7, 2023 2:48 AM UTC
  • 3 replies
  • 220 views
recently my outlook addin starting slowing my computer and doesn't automatically sync at startup anymore?  I have to restart smokeball.
Best answer by Sara Sultan
I strongly suggest you reach out to our support team here to see if there is something else they can find on their end.
View original
Sara Sultan
Smokeball Team
Forum|alt.badge.img+1
  • Smokeball Team
  • Jun 9, 2023 7:31 PM UTC
Hello Stephen,
This can happen if there are too many add-ins in Outlook.  Outlook is the most popular kid on the block for add-ins.  Almost every software wants to be friends with Outlook (us included 😉).  I suggest removing any unwanted or unused add-ins.  To do this go to File>Options>Add-ins in Outlook and click on the Go button.
This is a screenshot of my add-ins.  You will note this is not even all of them, I still have to scroll!  I have unselected quite a few that I do not use.  This should help with your issues.  If not, please reach out to our support team here.
  • Author
  • Contributor
  • Jun 10, 2023 2:44 AM UTC
Thanks, But I have only one add-in and that is smokeball, any ideas if That is not the problem?
Sara Sultan
Smokeball Team
  • Smokeball Team
  • Answer
  • Jun 13, 2023 2:46 PM UTC
