Solved
First technical problem I have encountered
  • Apr 18, 2023 4:40 PM UTC
  • 2 replies
  • 227 views
Hello, for some reason this morning, I am unable to open any of my SmokeBall matters, and I have shut everything down and restarted my desktop and there is no change.
Is anyone else having this issue and/or does anyone know how to resolve it?
Thanks very much.
Still a new SB user in NM
Martha Carpenter
Best answer by Melania
Hi @Martha.l
Hopefully this issue is resolved for you now! However, we do recommend restarting the computer (as you had already done).
It may even be worth logging out of Smokeball, and then logging back in.
If from there the issue persists, it would be best to contact a team member from the Support desk to try and resolve the issue for you!
View original
Forum|alt.badge.img+1
  • Smokeball Genius
  • Apr 18, 2023 9:30 PM UTC
I suggest you try closing and re-opening smokeball to see if the problem persists. If it does, call smokeball technical support. They can log in to your computer and try to resolve the problem. Generally if they cannot fix it then they will do an uninstall and reinstall for you while you do other things.
Melania
Smokeball Team
Forum|alt.badge.img
  • Smokeball Team
  • Answer
  • Apr 20, 2023 3:21 AM UTC
Hi @Martha.l
