Solved
Excel - document container?
  • Jan 1, 2023 8:05 PM UTC
  • 2 replies
  • 143 views
Forum|alt.badge.img
is there any way of saving an excel workbook so as to make it availabe in every new matter?
Best answer by Sara Sultan
Hello Sheldon,
You can upload an Excel document to the Forms and Templates library, but as Jonathan said, you cannot add in any automation fields.
View original
Forum|alt.badge.img+1
  • Smokeball Genius
  • Jan 3, 2023 2:24 AM UTC
I believe the answer is no. Similarly, you cannot add automated fields to Excel. You can however do some light formula work in tables in Microsoft Word. I have used this to some effect. See Use a formula in a Word or Outlook table - Microsoft Support.
In theory, you could also hire a programmer to develop a solution to your specific problem within a Microsoft Word (.DOCX) file to be uploaded as a template.
Sara Sultan
Smokeball Team
  • Smokeball Team
  • Answer
  • Jan 3, 2023 2:56 PM UTC
Hello Sheldon,
