Editing running timers and restarting saved timers
  • Feb 1, 2023 2:28 PM UTC
  • 1 reply
  • 83 views
Good morning,
Our firm has just switched over to Smokeball. There are two features of the timekeeping function that seem to be missing:
  1. If you have a draft timer running - you can’t pause and manually edit the amount of time in the timer (e.g. if you forgot to run the timer or forgot to stop the timer);
  2. Once you have saved a timer and it appears in the Time Entries list - you can’t restart that timer.
Has anyone found a work around? We like to have just one time entry per person per matter per day, rather than 5 different time entries for a person on the same matter in one day.
We’ve found this very frustrating. If you would similarly like to have these features added, please submit a feature request!
thanks,
Deb Collins
Yeng Collins Law, PLLC
1 reply
Sara Sultan
Smokeball Team
Forum|alt.badge.img+1
  • Smokeball Team
  • Feb 1, 2023 2:36 PM UTC
Hello Deb,
Thank you for your feedback and encouraging others to submit feature suggestions.  Here is a link to submit the suggestion for their convenience.
