Solved
Automation for Conveyancing
  • Oct 5, 2023 5:03 AM UTC
  • 1 reply
  • 81 views
Hi All,
I am developing a precedent for my own use in conveyancing matter. I am at a point trying to list out the fees we need at settlement. So I try to use the following field
<<Settlement Financials/Amounts Required to Settle Table List (2 columns)»
It seems this field is not working and it happens to all the table list fields. Can anyone share how to make it work?
Thank you.
Best answer by Sara Sultan
Hello @MicW
For fields that have table in the name, you need to place the field in the first cell of a table of however many columns is stated in the field name.  Simply place a one row two column table in the document and add the field to the first cell for this field <<Settlement Financials/Amounts Required to Settle Table List (2 columns)» to work.
View original
1 reply
Sara Sultan
Smokeball Team
Forum|alt.badge.img+1
  • Smokeball Team
  • Answer
  • Oct 5, 2023 1:41 PM UTC
Hello @MicW
