Solved
Adding other documents to the document container besides letter templates
  • Oct 11, 2023 5:33 AM UTC
  • 2 replies
  • 108 views
When I add documents such as a file note template to the document container and they are categorised as ‘other’, is there a way to access these documents in every matter like how you can access letter templates under ‘letter/fax’ in an open matter?
Or do they need to be categorised as a letter to be accessed easily from the letter/fax button.
Best answer by Sara Sultan
Hello Kirra,
You will want to categorise them as Letter for easy access.
View original
Sara Sultan
Smokeball Team
Forum|alt.badge.img+1
  • Smokeball Team
  • Answer
  • Oct 11, 2023 2:03 PM UTC
Hello Kirra,
  • Author
  • Contributor
  • Oct 11, 2023 10:33 PM UTC
Ok thank you!
