Tutorial
HOT TIPS: How Archie Helps Lawyers Organize, Summarize, and Manage Matters Faster
  • May 8, 2026 12:15 PM UTC
  • May 11, 2026 5:08 PM UTC
  • 0 replies
  • 176 views
check out the Archie Prompt Library!
Huma
Smokeball Team
If you’ve been nervous about using AI prompts to help with your legal practice, maybe we can help provide more clarity and color on that. This is not a tool that will ever replace human judgment and personality; rather, it frees up your strategic, analytical mind from rote, repetitive tasks so that you can focus on the case. There are so many operational challenges to running a law firm - managing tranches of documents, client communications, numerous and ever-changing deadlines, billing and reporting, case management, court hearings - all while maintaining accuracy, competence, ethics, and confidentiality.
That’s why many firms are turning to AI-powered legal assistants like Archie within Smokeball.
Archie’s Prompt Library allows legal teams to create, save, organize, and reuse AI prompts directly inside their matters. These prompts help with the tasks that eat up your entire day: summarizing case status for clients or other members of the legal team who need to know, reviewing recent correspondence, and drafting routine emails and letters. Instead of repeating the same administrative workflows every day, firms can standardize common tasks and access contextual information faster.
The Archie Prompt Library is Smokeball’s centralized repository for reusable AI prompts. Lawyers can access prompts directly inside the workspace and in each matter, save frequently used workflows, and launch prompts with a single click.
The system allows firms to:
  • Save and reuse prompts
  • Edit or duplicate existing workflows
  • Organize prompts by matter type
  • Share prompts across teams
  • Chain multiple prompts together
  • Launch prompts from the Precedent Library
  • Create standardized outputs across the firm
In this way, AI prompts help eliminate repetitive setup work. You can build prompts once and use them over and over, speeding up the rote tasks that take valuable time away from advising clients. With Archie, you can generate detailed matter summaries, review uploaded documents, draft client updates, organize case timelines, prepare internal memos, summarize billing and event activity, and more. This saves time, improves consistency, standardizes your process the way YOU want, and makes it really easy to onboard new hires or transfer cases between attorneys or firms. And because Archie works within the actual matter data, responses are grounded in the file itself rather than generic AI outputs.
Modern law practice moves at breakneck speed - or, at least, it sure feels like it. As caseloads grow and client expectations increase, you still only have the same 24 hours in the day. Firms need tools that help lawyers work more efficiently without sacrificing quality or oversight, and that’s where Archie can help from directly inside each of your Smokeball matters.
To learn more about how you can use the prompt library to trim the repetitive slog from your workday, check out this detailed video tutorial and written step-by-step instructions that walk you through this sophisticated but very intuitive tool. If you can use Google, you can use Archie within Smokeball. You can also reach out to your Trainer, Onboarding Specialist, and/or Account Manager to set up some time to guide you through this great legal innovation.
