Question
Timekeeper Entries Showing Zero
  • Oct 2, 2024 3:41 PM UTC
  • 1 reply
  • 53 views
Timekeeper Rates have been set and applied to the matters but the timekeeper’s entries are showing “zero.”  What is at issue?
1 reply
Sara Sultan
Smokeball Team
Forum|alt.badge.img+1
  • Smokeball Team
  • Oct 3, 2024 5:29 PM UTC
Hello @dschlueter
If you are using a Billing Activity Code for your time entries, that may override the matter rate setting.  Otherwise, I would need more information as to how you are entering your time to assist.
