Question
Time entry of less than one hour
When I add a time entry and put in less than an hour (0.8 or 0.75), as soon as I start typing the description, the time entry changes back on 1.
How do I change for amounts of time that are not an hour? Like 1.5 or .8, etc?
I am using the TexasBar Smokeball.
Sara Sultan
Smokeball Team
Forum|alt.badge.img+1
Hi Chip,
This is likely due to settings you have.  Click on the settings gear in the lower left and go to Firm Settings.  Under Staff and Users, open your staff card and make sure you have not turned on the Enter Time Entries as Units.
Under Time & Activities make sure you have set the correct billing increments for your firm as well.
Thanks. My settings were OK. Any other ideas?
Sara Sultan
Smokeball Team
Hey ​@chiptransisto
We will need to set up a screenshare to investigate what is going on at this point.  I will reach out privately to set this up.
