Solved
Save and close in word not saving to matter
  • Oct 6, 2023 6:34 PM UTC
  • 1 reply
  • 122 views
I have created dozens of documents and automated them. Recently I have a weird issue.
I created an automated word document. The automation works fine. However, this particular document when I hit save and close it does not save to the matter. it saves to a temp file. This is the only file that does it and I am not sure why. If I hit save as it shows document and when I save it saves to the matter. Most of the time I just open the document and make whatever tweaks I need then hit save and close.
Any ideas?
Best answer by Sara Sultan
Hello @FLW
This is a support issue.  You can connect with them here the next time you have an issue.  No need to do so on this as I have already made a ticket on your behalf.
View original
1 reply
Sara Sultan
Smokeball Team
Forum|alt.badge.img+1
  • Smokeball Team
  • Answer
  • Oct 6, 2023 7:10 PM UTC
Hello @FLW
