Question
Problems with smokeball compatibility
  • Nov 28, 2024 12:20 AM UTC
  • 3 replies
  • 369 views
Hi there,
 I was wondering if anyone had any ideas or suggestions.
I am a recent user of smokeball. My laptop is 3 years old and was struggling to run smokeball and other applications at the same time.
I bit the bullet and recently bought a new laptop so I could run smokeball and other applications. I bought a top of the line laptop with more RAM (32GB) same brand as my existing laptop (Lenovo) same operating system (windows).
When I went to download smokeball on the new laptop, I had all sorts of problems. I rang smokeball support for help. They tried to install smokeball and had issues. Finally I was told that smokeball doesn’t support the processor that my new laptop has. The processor is Snapdragon(R) X Elite - X1E78100 - Qualcomm(R) Oryon(TM) CPU   3.42 GHz.
Does any of this sound right? Are there any work arounds or solutions? Otherwise it seems that I have spent $3000 on a new laptop for my business that I can’t run smokeball on.
Any help appreciated.
Thanks
Forum|alt.badge.img+1
  • Smokeball Genius
  • Nov 28, 2024 6:42 PM UTC
​@rumpole return the computer and purchase one with an intel or AMD “x86” processor. What you purchased has what is known as an arm processor. Arm processor computers cannot run software designed for X86 computers unless there is software emulation on the arm system to run the x86 software. I am extremely skeptical that Smokeball could ever be emulated well on an arm system without a full development team working on that issue because Smokeball desktop depends on other software such as for SQL database.
Here is the support page showing system requirements  note “No Arm”.
https://support.smokeball.com/hc/en-us/articles/17274499748759-Smokeball-System-Requirements
  • Contributor
  • Apr 10, 2025 12:11 PM UTC
I just got a new MS Surface Laptop today with Snapdragon(R) X 10-core X1P64100 @ 3.40 GHz and 16GB RAM.
When I installed Smokeball I got an installation failure message, but after a little panic I saw it had placed the shortcut to open it on my desktop so I double clicked it and it actually had installed just fine and works very well. Outlook and MS Word integrations work as do all the browser based reports.
I don’t use scan to Smokeball anyway but if you have a Canon printer and need an ARM driver apparently this one works, I’ll give it a go tomorrow in the office: https://www.support.xerox.com/en-us/product/global-printer-driver/downloads?platform=win11arm64&language=en&attributeId=
I suspect the Windows 11 x88 emulation for ARM has improved more recently. The battery like of my ARM laptop has been awesome this evening getting it all set up for work tomorrow.
  • Contributor
  • Apr 11, 2025 1:47 AM UTC
I can confirm that the universal ARM Xerox driver works just fine with my Canon printer for printing and scanning. So there really seems to be no issue at all with the ARM processor and using Smokeball, at least for my setup.
