Question
Preventing duplicate contact creation and cleaning up duplicate contacts
  • Oct 21, 2025 8:04 PM UTC
  • 14 replies
  • 281 views
Sam King
Smokeball Team
Do you find it too easy to create duplicate contacts in Smokeball? Are you struggling to identify duplicates or find yourself putting the wrong contacts onto your Matters or Invoices because there are too many “versions” of the same contact? We want to hear from you!
Smokeball is currently investigating methods of tidying up pre-existing duplicate contacts and ways of making it easier to prevent their creation in the first place. If you would like to discuss this topic with the Product team, please like this post or reach out to sam.king@smokeball.com and someone will be in touch with you. Thanks!
Sara Sultan
Smokeball Team
Forum|alt.badge.img+1
  • Smokeball Team
  • Oct 21, 2025 9:48 PM UTC
Thank you so much for working on this, Sam!!!!!!!
taylora
  • Contributor
  • Oct 22, 2025 10:13 PM UTC
Yes!  This is something I’ve wanted for a long time and I’m glad to hear it’s on the drawing board.  I’d be happy to speak to someone about this.
Brad
  • Contributor
  • Nov 14, 2025 8:02 PM UTC
Sam, I have spent hours cleaning up duplicate contacts (usually a result of someone just entering a name fresh when adding them to a matter, rather than scrolling through the list that pops up after typing part of their name). This was quite common with an accountant who worked on multiple trust accounts. It also happens frequently with LEADS; either an existing client contacts us via our website’s chat bot or intake form, or a potential client submits a chat AND an intake form. There are often situations where there is different information in each LEAD so being able to merge them would be most helpful.
Sam King
Smokeball Team
  • Author
  • Smokeball Team
  • Nov 16, 2025 9:34 PM UTC
Great insight ​@Brad - I will reach out with a few follow-up questions for you via email. Respond at your leisure!
Any update on this? I’m hoping there is a tool I might use to help clean up our duplicate leads/contacts
Sam King
Smokeball Team
  • Author
  • Smokeball Team
  • Sep 3, 2026 11:20 PM UTC
​@XandriClifton - Smokeball recently released 2 features that should help with this problem:
  • When you assign a contact to a role on a lead/matter, you are first prompted to select an existing contact before going onto create a new one
  • When you are about to save a possible duplicate, a check occurs before the contact is saved. If the system thinks you might be about to save a duplicate, we tell you and surface possible matches before allowing you to override the challenge and save the contact. Matching data is visible and the search is weighted on Phone, Email and Full Name data
Have you noticed these recent changes? Do you think they are assisting in the prevention of contact duplication?
The team is also in the design/validation phase of a merge contact function. If you would like to chat about this, “thumbs up” this comment and someone from the team will reach out for a chat. Thanks!
Hi Sam, thanks for your response! We have noticed these futures and they are helpful--however we have a third party that is able to add leads into our system (smith.ai). They don’t have full access to our account; they can just send leads into our system. I was hoping for a way that SB would flag duplicates for a staff member to review and merge, if applicable. Thanks!
Xandri
Sam King
Smokeball Team
  • Author
  • Smokeball Team
  • Sep 7, 2026 6:51 AM UTC
​@XandriClifton - thanks for the feedback! I have reached out to our partnerships manager to raise with Smith.AI. I would like to catch duplicates for you BEFORE they reach the system, if possible. Otherwise, the merge contact feature we are working on should help resolve a lot of this pain. It will not prevent Smith.AI or any other integrated products from creating duplicates however, so I think it’s worthwhile looking into solving that as a separate issue.
  • Contributor
  • Oct 27, 2026 5:31 PM UTC
​@Sam King thank you for this timely update!  We are in cleaning up duplicates right now.  Do you need a volunteer to test the merge contacts feature?
Sam King
Smokeball Team
  • Author
  • Smokeball Team
  • Oct 27, 2026 9:47 PM UTC
​@RCostella - eventually, yes! I have noted your firm as a potential beta tester. Thanks for your interest and feedback!
  • Contributor
  • Oct 28, 2026 3:18 PM UTC
I have a question. We have a large business department. Occasionally, individuals from those businesses need personal estate plans. If I update their contacts with their personal information, it takes out their business information. Is there a way to separate them or do they just have to be separate contacts entirely?
Sam King
Smokeball Team
  • Author
  • Smokeball Team
  • Oct 28, 2026 11:26 PM UTC
​@mbechtelgdwo - good question! You shouldn’t really need to, as the base Person contact supports some work-related information such as Work Phone and Email (though a single Email field, multiple can be saved if delimited via semi-colon), and in the Matter Contact view who that person is at the overall Organization is qualified via the Role field. Besides a possible Business Email field to de-couple those pieces of information and allow for separate utilization (email generation, document automation, etc.) is there other information missing? In your comment, can you expound on what you mean by “If I update their contacts with their personal information, it takes out their business information”?
  • Contributor
  • Nov 5, 2026 3:53 AM UTC
Hi Sam,
Looking forward to this being fixed as it is a huge issue in our firm.
Are you also looking at fixing the issue where you can still see all your deleted duplicate contact cards and ex staff members when using Smokeball Billing.
For example I would love to not have to scroll through every single now deleted bank branch in order to find the correct contact card to use.
Thanks
Sam King
Smokeball Team
  • Author
  • Smokeball Team
  • Nov 5, 2026 5:00 AM UTC
​@awark - yes! Pretty soon you’ll see deleted contacts removed from search results in web in places like the New/Edit Matter, New/Edit Lead, and New Phone Message pages! Are there are places in the web product you would like to see them removed from, as a priority?
