Solved
Power and Estates Register
  • Sep 25, 2023 5:36 AM UTC
  • 1 reply
  • 141 views
Wondering if there is a Power and Estates Register within the Safe Custody Register? Thanks.
Best answer by Tony Hastings
Hi @KateL
While we do not have specific registers within Safe Custody, you can select a category for each document that you are holding. We have many existing categories but you can also create your own custom ones.
You can then filter the Safe Custody report by the document type to create a list of that particular category.
View original
1 reply
Tony Hastings
Smokeball Team
  • Smokeball Team
  • Answer
  • Jan 24, 2024 11:40 PM UTC
Hi @KateL
