Solved
Not being prompted for MFA upon closing out of SB
  • Nov 12, 2023 10:36 PM UTC
  • 1 reply
  • 59 views
We recently enabled MFA on our SB accounts firm wide. What we have found was that if you only close out of SB using the “X”, you won’t be prompted to login again (or enter MFA) upon opening SB the next time. So closing out of SB using “X” alone doesn’t trigger your SB to log out.
It appears that you need to press log out of SB at the end of the session in order to be prompted to log back in using MFA.
It would be great if closing out of SB using the red “X” meant it logged you out.
Best answer by Sara Sultan
Hello Victoria,
I will let the Product team know your feedback.  If you would also like to put in a feature suggestion for MFA to apply on every time Smokeball opens, rather than logging in, you can do so here.
View original
1 reply
Sara Sultan
Smokeball Team
Forum|alt.badge.img+1
  • Smokeball Team
  • Answer
  • Nov 13, 2023 7:48 PM UTC
Hello Victoria,
