Solved
Matter Infor: Inter Reference
  • Oct 25, 2023 3:00 PM UTC
  • 2 replies
  • 102 views
When Smokeball did their latest update, they took away the Matter Infor: Internal Reference. This future used to be available when setting up a “Lead.” Now, it is only an option when converting the Lead to a Matter. I need to be able to add the Internal Reference number prior to opening a case matter. Part of my role in the Law Firm I work for, I am the one builds the file and hands it off to the paralegal. Would it be possible to add this feature back for as a LEAD?
Best answer by Jeff Bensch
Hello,
I am with the Support team. This feature has not changed. There is a toggle in the internal reference settings that may have been switched off. I am going to create a ticket an our team will reach out. Thanks!
View original
  • Smokeball Team
  • Answer
  • Oct 25, 2023 3:23 PM UTC
Hello,
  • Author
  • Contributor
  • Oct 25, 2023 3:38 PM UTC
Hello Jeff,
Thank you for the FAST response!!! The issue has been resolved! Thank you so much!
