Question
Matter Hold - Past Due
  • Jul 21, 2026 5:02 PM UTC
  • 3 replies
  • 84 views
Is there a way to put a matter on hold because a client isn’t paying their bill?
Huma
Smokeball Team
  • Smokeball Team
  • Jul 22, 2026 3:57 PM UTC
Maddie, when you say “on hold,” what does that look like to you in an ideal state? A special color for tagging the file, a change in user/access permissions so staff knows not to do additional work, a default message in the client portal, etc? I’m trying to understand more about the specific functionality that would be helpful to you here. Thank you!
  • Author
  • Contributor
  • Jul 22, 2026 4:04 PM UTC
Hi Huma. A change is user/access permissions so staff knows not to do additional work is my desired outcome.
Sara Sultan
Smokeball Team
Forum|alt.badge.img+1
  • Smokeball Team
  • Jul 22, 2026 8:38 PM UTC
Hi Maddie,
I would suggest putting on a Matter Tag for this.
