Question
How do I add a detail to a Lead Matter Settings (Matter Details)?
  • Mar 27, 2025 4:39 PM UTC
  • 4 replies
  • 98 views
When I set up a Lead for a new probate, there is no “beneficiary” detail in the Matter Details. How do I add that option?
  • Regular
  • Mar 27, 2025 4:55 PM UTC
​@C Bunker  reach out to Smokeball Support to see if they would make that field available for Probate Leads. Include an explanation of why having that field available in a Lead would be beneficial.
  • Author
  • Contributor
  • Mar 27, 2025 4:57 PM UTC
I was hoping it was a step I was missing, but I will submit a request
  • Regular
  • Mar 27, 2025 5:06 PM UTC
​@C Bunker I checked the matter settings before responding and unfortunately that field just isn’t available in Probate Leads. If you are unfamiliar with the the matter settings, click the cog icon in the upper right of the Lead window (to the right of the timer and left of the question mark) to see all available fields for that type. If the field isn’t in that list, it just isn’t currently available.
Sara Sultan
Smokeball Team
Forum|alt.badge.img+1
  • Smokeball Team
  • Mar 28, 2025 10:02 PM UTC
Hello All,
Smokeball intentionally keeps Leads very light on contact options as they are not yet clients.  However, please do reach out to support to request this so they can capture the feedback.
