Solved
Field Insertion for multiple clients
  • Oct 29, 2022 7:31 PM UTC
  • 2 replies
  • 196 views
Forum|alt.badge.img
I have a case where I will have over 50 clients in the same case, and I need a contract for each one.  I have an automated form for individual cases that automatically puts in the client name, address, phone and e-mail address in the contract.  This works great for 1 plaintiff cases, but I can’t figure out an efficient way to do the automation for individual contracts for cases with more than 1 client.  Is there a way to do this?
Best answer by Kalina
Hi Nick,
Is this a Litigation matter type? You can add a party ask to the document template.
  1. In Modify mode, expand the Details section and select Plaintiff for Addressee. Save & Close the template.
  1. When you open the document in a matter with multiple plaintiffs, Smokeball asks:
    • Who to generate the form for, and;
    • once you select multiple plaintiffs, whether to generate a separate document for each selected contact.
The following Smokeball Support Hub article contains further information: Create letters to multiple recipients.
Is the above helpful for your requirements?
View original
Kalina
Smokeball Team
  • Smokeball Team
  • Answer
  • Oct 31, 2022 11:39 PM UTC
Hi Nick,
Forum|alt.badge.img
  • Author
  • Contributor
  • Nov 1, 2022 12:05 AM UTC
Thanks. That is exactly what I needed.
