Solved
Debt Recovery - recording payments
  • Feb 29, 2024 6:50 AM UTC
  • 2 replies
  • 126 views
Hi there,
Is there a way of recording payments on a matter.
For example, say you initiate legal action against a debtor for $50,000 and they pay $10,000 upfront then $1,000 per week, how do I record this in the matter so I can keep track of the balance?
Thanks
David
Best answer by Sam Stephens
Hi @David L ,
Sure thing, it sounds like what you may need is Payment Plans.
Payment Plans are designed for exactly that - if you have $50k outstanding for your debtor, you could record the $10k they paid up front, and then can add a payment plan for $1k per month thereafter.
There’s more information how how it works, and how you can set it up here:
https://support.smokeball.com/hc/en-au/articles/6099425396759-Set-up-payment-plans
Does this look like it’ll solve your needs?
cheers
Sam
View original
Sam Stephens
Smokeball Team
Forum|alt.badge.img+1
  • Smokeball Team
  • Answer
  • Feb 29, 2024 11:58 PM UTC
Hi @David L ,
cheers
Sam
  • Author
  • Contributor
  • Mar 1, 2024 12:05 AM UTC
Hi Sam, thanks for the reply.
My version of Smokeball looks a little bit different than the one in the link you provider. And I don’t see a Payment Plans options in my Contacts (or anywhere on SB).
Also, I need to record payments from defendants in litigated or debt recovery mattes, not clients wanting to pay off their invoices.
Thanks
David
